Low/Reverse clutch stack 700R4
Old 05-08-2005, 04:41 PM
M93Z's Avatar
Question Low/Reverse clutch stack 700R4
The manual call for the stack to measure 1.20 - 1.24 in; but the instructions that came with the parts from GM call for a height of 1.15 - 1.18 in. The set that I removed was about 1.16 in. Which is better?
Thanks.
Old 05-09-2005, 10:38 AM
insaneclown's Avatar
My new stack was the same height as the old stack, which wasn't worn much anyway. Probably about 1.16 inches like yours. I went with that height and it worked fine.
Old 05-12-2005, 06:45 PM
M93Z's Avatar
Anyone else who has rebuilt a trans?
Old 05-12-2005, 07:41 PM
BudH's Avatar
I added selective plates to bring mine to the 1.20 - 1.24 spec!
Works good!
Old 05-13-2005, 05:24 PM
jxaxsxoxn's Avatar
The first ones to go into the case.
Stock specs work ok.
Just don't use stock specs on the 3-4.
Old 05-13-2005, 07:04 PM
M93Z's Avatar
Thanks, I'm going to try the Z-Pack on the 3 - 4.
Quick Reply: Low/Reverse clutch stack 700R4
