upgrading gears, what do i need?
i am going to buy 3.42 gears to upgrade my current 2.73 gears. what do i need exactly to do the upgrade? do i just need the gears or is there more that i have to get when doing the upgrade?
what kind of results will i see with this upgrade?
I would get a master rebuild kit, and some nice tools, and depending on miles, maybe a new differential... why 3.42 and not 3.73? you should def notice a difference over 2.73...
If you have never done gears, have someone who ahs help... unless you are overly confident like myself
do a search on gear install for the fullsizechevy.com install guide... its a life saver
I did that swap by my self, 2.73--3.42, and everything turn out very well. No noise and a great diffrent in accelerate. I did that all the way, new Eaton and all bearings.
How much $$ do you think someone would spend on special tools to do this job. I'm planning on getting 3.73s to replace my 2.73s. I heard install costs a lot so I'm planning on doing it myself. Any certain brand name of gear that you would recommend or stay away from?
14 Second Truck Club
If you are upgrading from a 2.73 to a 3.42 or 3.73 you will need either a thick gear(for a 2 series case), a new diff case, or a ring gear spacer(not reccomended). Just upgrade to the Eaton if you have the cash. As far as tools- in/lb torque wrench, dial indicator, magnetic base, a really good impact if you are using a crush sleeve. You really dont need a pinion depth setting tool, you can use a caliper/micrometer to measure your shims and pinion.
My gears come from GM-Motive, I think they are o`key. Here you can read about
the gear change http://www.fullsizechevy.com/fscu/axletech/
