Need Help....Crankshaft oil deflector...
Old 05-12-2005, 09:58 PM
chase311's Avatar
Default Need Help....Crankshaft oil deflector...
Ok first off...im building a 383 on a ls6 block...4 inch crank 6.125 rods..problem is that the crankshaft oil deflector i just bought when its installed the crankshaft hits it when i turn it over by hand...im guessing this is due to the longer stroke...I need suggestions PLEASE on how to solve this...i dont think i can just leave this part out because the oil pickup tube sits ontop if im correct...any help would be great...thanks again guys...
Old 05-12-2005, 10:01 PM
I can shift faster than you.
Jason99T/A's Avatar
Space the windage tray up with some washers. This is very common on the 4.00" stroker crankshafts.
Jason
Old 05-12-2005, 10:14 PM
chase311's Avatar
Awesome..thanks abunch jason...
Old 05-12-2005, 10:27 PM
xssive's Avatar
You are going to most likely have to cut and weld the oil pickup tube bracket as well since it will be spaced up , decreasing the distance between the pickup and the bottom of the oil pan.
