TPS problem.
TPS problem.
Just did a log and HORIST (as usual) noticed that my TPS was only opening 70%. Well I found out I had a vacuum line stopping it from opening it. No problem just moved it. I then with the engine off scanned and mashed the throttle. It opened to 100%...cool. But when I started the car and drove it only went up to 80%. Stopped the car and just turned the ignition to the ON position mashed it again and went back to 100%. Anyone know whats up with that??
Originally Posted by Y2K SS
Hmmmmm.. I must have missed something.
I will not help you further until you do so or until you send me the updated TPS report ... oh and ... you red stapler... I want it back
Originally Posted by horist
you MUST go to the local rental store and rent "Office Space"
ok, I went out and checked the physical travel of the throttle and it's only opening about 85%. This would explain a whole lot...
Is there any way to adjust this? It's about 15 to 20% of the way from hitting the bump-stop on the throttle-body itself so I think grinding that would be somewhat useless at this point.
How do you adjust the throttle cable?
Location: Live Oak, FL - in the woods where the creatures lurk.
Originally Posted by Drew778
You don't need no stinken floor mats, thats just more weight
