Where would you set idle on this cam?
Here is the car:
2002 LS2 manual transmission.
Ported Throttle Body, smooth bellows, SLP Underdrive Pulley
Comp Cams shaft installed:
GRIND #: LS1 3767R /3753R HR114.0
GROSS VALVE LIFT .532 .535
DURATION @ .050 220.00 224.00
LOBE SEPARATION 114.0
ROCKER ARM RATIO 1.70
Dynatech SuperMAXX Header System {High-Flow Catalytic Converters & all oxygen sensors present.}
Assuming that you have everything dialed in, A/F ratio, timing correct, etc.
What rpm would you set the curb idle at?
Thank you!
Thank you!
Originally Posted by fnbrowning
Here is the car:
Thank you!
Thank you!
ive got my f13 set at 800, 230/232 598/587 112+4, little bit of tuning and its ok, i still have more to do but the car idles steady there and the only other thing i did was put the idle airflow up for now by about a point or so in the higher temps and multiplied 400 800 and 1200 in the ve by .6 .7 .8, the car runs good and it sounds bad *** at 800 rpms lol
