Jesel non adjustabel shafts what pushrod length
If you had stock heads/stock headgasket, stock cam, basically a bone stock motor, what length should you end up with for pushrod to get near stock preload?
Throw a .012 thinner gasket on there (.040 cometic) and a .015 thou shim under the rocker stand ought to keep it within a few thou
Id have to guess for a dead stock setup a 7.3, or 7.325 pushrod would do it
