bigger injectors what do i change?
Old 05-30-2005, 09:40 PM
rons 00z's Avatar
Default bigger injectors what do i change?
I just put in a set of 38lb's from the stock 26# and was wondering on what tables do I have to change on HPtuners to accomidate? I'm just getting used to this software so sorry in advance if I ask something ignorant. Also my o2's are reading around
O2B1S1 907 -920
O2B2S1 942 -942
They move around a little bit but thats the area they run. Thats super rich right? Where do I go to fix that and what increments should I adjust in?
Anything else you guys would like to know about my scans I encourage you to ask away so I can learn this stuff. thanks, Ron
Old 05-30-2005, 10:31 PM
soundengineer's Avatar
www.audiohelix.com/hptuners/injectors.xls
I have already put in the right #'s for it to be for your 38# injectors...
copy and paste injector flow lbs/hr into flowrate vs kPa
Old 05-30-2005, 10:44 PM
Bow94z's Avatar
Tune?
Old 05-30-2005, 11:24 PM
rons 00z's Avatar
Originally Posted by Redzme8
Tune?
i had a mail order from HPE but since then i've put 38# injectors in which puts me in the situation i'm in now
Old 05-30-2005, 11:36 PM
rons 00z's Avatar
wow thats awsome man thanks alot. i guess my numbers were way off like 26-28. so with my numbers in flowrate vs kpa being so off what would that cause the injectors to do?
