Lost power
Old 05-31-2005, 06:10 AM
T/A-Speedfreak's Avatar
Default Lost power
I was making 400rwhp/390rwtq with an LPE gt2-3 cam.
I rebuilt the motor added long tubes and FM13. Results were 398RWHP/379RWTQ and the torque curve sucks. This seems strange to me. Both tests were on the same dyno.
Here is the only thing that I don't know for sure. I had the heads surfaced and when I picked them up from the machine shop they told be they milled them. I asked them about that because when I had it done at MTI they came back shaved just enough that you could still barely see the gasket material. This time they came back completely clean with a lot of metal shavings on them. I asked them how much did you mill them and the answer was I don't know, a couple of thousands. Anyways, they were already milled .15 plus the MTI cleaning now this unknown amount.
I notice that the engines valves aren't as loud(slaming shut). Do you think that the pushrods(7.4s)are now too long and the valves aren't closing? Would this cause a lot of power loss? Anyone have a different idea. The heads btw are GTPs. Thanks.
Old 05-31-2005, 08:08 AM
Restricted User
2001 Pewter WS6's Avatar
When you say you rebuilt the motor, did you puit in new rings and bearings? Did you use standard or low tension rings?
Old 05-31-2005, 08:17 AM
LS1 BU's Avatar
Something is wrong. I don't see you losing power. Also I thought you could only mill .015 off the heads and have proper clearence with that cam?
Old 05-31-2005, 08:37 AM
PREDATOR-Z's Avatar
As stated above, it could be a variety of things and too long p-rods could be the problem causing too much preload (W/ non adjustable rockers)
IMO measure the head deck thickness, that will tell you how much it is milled. Once this is known, you can make a decision on the p-rods.
Can you post a graph of your dyno??
Old 05-31-2005, 12:14 PM
cyphur's Avatar
I changed the title, only so you all would quit griping an answer his question. So....lets get this back on track.
Edit....cleaned up the thread a little as well.
Old 05-31-2005, 12:17 PM
LS1 Sounds's Avatar
Originally Posted by Drew778
Dude, he came here asking for help and all you guys have to say is you should change the title, STFU ALREADY
And one of the things the fixed my problem was going back to my LS1 edit tune so HPT STILL SUCK IN MY BOOK
This will be my last reply to this thread, if you want to contact me further do it using PM's.
The reason this site even exists for him to ask his questions is because of sponsors, one of which is Futral Motorsports. Why would any business in their right mind allow someone to bash a sponsor's product without evidence that it actually caused a problem?
He came here asking for help, and I see none offered in your reply so I guess that makes us both equally helpful. Also, he could have asked for help without bashing any product...
Regarding your tuning problems... I can't help it if you can't figure out how to use HPT...
Old 05-31-2005, 12:36 PM
PREDATOR-Z's Avatar
Guys, there was no bashing IMO.
It was evident from the rest of this thread, that the FM 13 was not the culprit.
This is not editing. This is censorship.
Pardon me for saying that the power given to directors is being slightly overused here.
You guys know that I love being here, but please, let us not turn into media freaks.
Respectfuly
Mark
Old 05-31-2005, 01:00 PM
cyphur's Avatar
I didn't edit this thread b/c Futral was mentioned, I edited it b/c those posts were entirely off topic and didn't help him achieve his goals whatsoever. Please keep this thread on track and address any issues you have with me via PM.
If you notice the first post still claims the F13 is the culprit. Don't you think if I was protecting Futral's interests I would edit that out as well?? C'Mon now....
Old 05-31-2005, 02:00 PM
PREDATOR-Z's Avatar
I PM'd you back. After reading it, I hope you understand my reaction.
No harm intended.
Old 05-31-2005, 03:48 PM
No Fm bashing from me, there are too many people making good power with them(cam only), that's why I went with this cam. What I am asking for are ideas of why I would lose power when clearly the changes I made should have gained me some power. I suspect that the heads might be milled more that my guess of .20th. BTW, I fly cut my pistons but the cam should have cleared with the heads milled .30 as long as my valves weren't 2.05's. I was hoping to hear the pushrods were my problem since I don't have the valve clatter I used to have with my last 2 cams. The heads have isky dual springs on them. Thanks again.
Old 05-31-2005, 05:17 PM
cyphur's Avatar
No harm intended.
Its all good
Speedfreak, find out exactly how much your heads are milled, figure out how much your pistons are flycut, and call FMS. They should be able to help you out a little.
Have you tuned for this cam already?
Old 05-31-2005, 06:18 PM
Have you tuned for this cam already?[/QUOTE]
Yes I have, I really hate to pull the heads and will do that as a last resort.
Old 06-23-2005, 03:39 PM
KB99WS6's Avatar
How you making out with this? Find the problem yet?
Old 06-23-2005, 03:42 PM
92SilverSHO's Avatar
so to run a fm13 on a stock motor, it wont fit the stock heads?
Old 06-23-2005, 05:21 PM
PREDATOR-Z's Avatar
sure it will
Old 07-27-2005, 08:08 PM
Greed4Speed's Avatar
Gotta be those Dutch engine building techniques.
