She Lives!!.....Again.
After 3 mostly sleepness nites, I got the beast running, sadly, not in time to make the Index Race, but I'll still do some T&T this weekend.
Made a vid of her running:
http://www.karsxtremeperf.com/videos/MOV02270.MPG
Crank It Up!!!
I was forced back into using my 23* heads, not the 18*s as planned, oh well, I did put a much larger cam in tho, took a couple of little launches, and it feels way stronger than it did last year
Hopefully the weather holds, and I'll find out!
Crank It Up!!!
421 cubes
AFR 220s full port
13.2 to 1
1100 Dom., Super Victor
w/1.6 rockers 712 - 688 276 - 284 @ .050
Stock Blk, splayed
Cola Crank
H-Beam 6.0 rods
Ross Pistons, etc...........
AFR 220s full port
13.2 to 1
Stock Blk, splayed
Cola Crank
H-Beam 6.0 rods
Well, initial time out went well, I ran a 6.84 after I found my throttle linkage was loose. This matches my best N/A pass from last year, and I still have tuning to do, and it was well over 20 degrees warmer than last fall when we were out.
Truck looks great. I'm also buiding a v8 s10, 1st generation style though. check out www.s-seriesforum.com/forum sometime.
There is no activity!!!!
PRY, thanx, I am pulling the mill out to fix a couple of oil leaks. Back out soon.
Originally Posted by CTSV05
Ummm, is this like brand new?
Went out last nite to a 1/4 mi. track.
Played with the 2 step a bit and got a 10.78 finally getting a 1.52 60. This is my best 60 so far and almost 2 tenths quicker at this particular track!!!
YEA!!! I went out in the semi-final, so I was happy, this was my first real attempt at competition with the truck. Lost by only .0970, I let off too much at the finish.
So the #'s are coming, I think a 10.60 something at this track may be possible.
The other 1/4 mi track is usually .15-.2 quicker.
