ls1 heads vs ls6 heads? is there a big difference
Old 06-09-2005, 12:04 PM
ibanez7's Avatar
Default ls1 heads vs ls6 heads? is there a big difference
Is there a big difference performance/flow wise between ls1 and ls6 heads, around the 2001 and 2002 era.
what are the HP numbers between the two.
also what numbers are on the casting so you know which heads you have?
is it better to upgrade from ls1 heads to ls6 heads or to just buy a quality ls1 heads from like AFR....
thanks guys!!!
Old 06-09-2005, 12:07 PM
Turo's Avatar
ls1 = 241 casting
ls6 = 243 casting
ls1 < ls6 < AFR
Old 06-09-2005, 12:09 PM
ibanez7's Avatar
cool and thanks!
Old 06-09-2005, 01:12 PM
SiL3NtXWS6's Avatar
LS6 are higher compression
Old 06-09-2005, 01:39 PM
ROCNDAV's Avatar
<shhh....dont move.....I dont think JRP can see or hear you...quickly, before he does...use the search button>
Quick Reply: ls1 heads vs ls6 heads? is there a big difference
