cam install, after 50 miles no oil pressure! HELP!
Old 06-10-2005, 07:33 PM
A&MWS6's Avatar
Default cam install, after 50 miles no oil pressure! HELP!
put a cam in today and everything ran fine until about 50 miles down the road then oil pressure went to zero, what could possibly cause this or how coul i fix this?
Old 06-10-2005, 07:40 PM
ss rally red's Avatar
Did you swap oil pumps also?
Old 06-10-2005, 07:41 PM
Tally TransAm's Avatar
did you put a new oil pump o ring in if you removed the oil pump
Old 06-10-2005, 07:45 PM
A&MWS6's Avatar
no did not change the oil pump.
Old 06-10-2005, 07:51 PM
Dont know how it would happen but just check to make sure oil pressure sending unit wasn't damaged or disconnected. When oil pressure whent to zip did the motor start knocking/ticking etc?
Old 06-10-2005, 07:55 PM
A&MWS6's Avatar
yea we were just sitting there listening to it and it started knocking pretty hard so i looked at the oil pressure and it was on zero
Old 06-10-2005, 08:08 PM
98TAauto's Avatar
did you do anything to the stock oil pump? Usually this happens if the o ring on the oil pump wasnt put on right or something else with the oil pump.
How many miles where on the oil pump thats in there? Sounds to me either something wasnt installed right or the oil pump died.. one reason most replace those when they swap cams. Some dont and they get by fine, but the added strain of the cam can kill some pumps that have miles on them
Old 06-10-2005, 08:13 PM
Turo's Avatar
Did you take the stock oil pump off at all during the install? If so, you might have accidentally installed the o-ring incorrectly. I would just tear it apart again and make sure everything is installed properly, better safe than sorry.
Old 06-10-2005, 08:19 PM
Rob
Rob's Avatar
Other thoughts:
Does it have oil?
Did you use air to install valve springs? I did and the chain put a hole in the oil pump...was rather a freak thing but could happen to somebody else.
