pistons not 3.898 that can be used with stock rods?
Old 06-11-2005, 02:37 PM
LS1_PNYTAMR's Avatar
Default pistons not 3.898 that can be used with stock rods?
the only ones i see for stock rods are all stock bore.. i want to slightly hone it out when i do it... no big deal or anything i guess... but i guess i was looking for like the 3.903 or whatever for use with stock rods...
Old 06-11-2005, 03:08 PM
HSV-GTS-300's Avatar
Try here
Diamond , JE & Mahle.
3/8 to 1/2 way down the page
Old 06-11-2005, 03:37 PM
thanks.. 3.905 is fine on ls1/ls6 block right?
Old 06-11-2005, 03:42 PM
Mahle Motorsport Forged 347 cid LS1 Flat-Top Piston Set: 3.908" Bore, 3.622" Stroke, 6.098" Rod Length, .945" Wrist Pins, 1.314" CH, -1cc Dish; Wrist Pins and Piston Rings Included
Price: $509.99
or
JE Forged Flat-Top Pistons with Wrist Pins, 3.905" Bore, 3.622" Stroke, 6.098" Rod Length (Stock LS1 Rods), -2cc Valve Reliefs, 1.34" Compression Height, .945 x 2.50 Wrist Pins
Price: $600.00
JE Piston Ring Set for LS1, 3.905" Bore, 1.5mm, 1.5mm, 3.0mm
Price: $179.99
or
Diamond Racing LS1 Forged Flat-Top with -2cc Valve Reliefs, 3.905" Bore, 3.622" Stroke, 6.098" Rod Length (Stock Connecting Rods); .945 x 2.50 Wrist Pins Included
Price: $569.99
Diamond Racing 3.905" Pro-Select Piston Rings, 1.5/1.5/3.0mm
Price: $179.99
mahle is definetly the cheapest... im doing pistons and rodbolts with stock rods and crank for right now.... well im not puttin them in just yet, but they'll be ready hwen i need them.. 150-200 shot with maybe a 250 shot once or twice. what ya think?
Quick Reply: pistons not 3.898 that can be used with stock rods?
