Gears & Axles - guys with 4.10s please
View Full Version : guys with 4.10s please
ls2 bait
06-15-2005, 11:55 PM
ok my car isnt anything much and at most it might see an ls6 cam--just the bolt ons now--i have 4.10s in my 10 bolt and they are getting noisy so im going to a 9 inch or 12 bolt soon. my question is my speedo seems to be ready around106-108 at the top of 4th--i know thats not enough to carry me thru the quarter at 115--is my speedo slow or is the 4.10 just a bit much? i know ive had to back out of 2 races already because i was out of gear. btw ive never had this car to the track thats why im asking and its an m6.
GuitsBoy
06-17-2005, 09:33 AM
You should be able to sneak in just under the rev limiter going through the traps. Especially if you have the ls6 cam and raise the limiter to 6500.
CATCH ME
06-17-2005, 10:31 AM
i go through in 4th with a limiter at 6700 and a speed of about 117
ls2 bait
06-17-2005, 01:03 PM
well right now im still on the stock cam so i never take it over 5800-5900. i dont drag it now because of the 10 bolt but it will see some track time once i get a good rear--i just dont want to spend 2 g's on a rear and have to swap the gears out because i cant make it thru the quarter.
btw what is the stock rev limiter?? i set mine to 6100 with the hypertech--too high or too low?
Vertigo
06-21-2005, 03:21 PM
Too low...set to 6400
GuitsBoy
06-21-2005, 03:56 PM
Why would you tell him to set his limiter to 6400 when stock valvesprings have their hands full at the factory setting of 6200. The stock cam dosnt make power up there anyway.
I would put it back to 6200 unless you have the mods to support spinning higher.
ls2 bait
06-21-2005, 09:06 PM
is 6200 the stock rev limiter? i think i had heard 6190 1 time. i forgot what it was when i did the hypertech for my gear swap and i put it at 6100. right now my light is at 5800 and i think its a tad low even. will it make a difference when i put on my lt's and cat back? right now its just a lid, gears, cutout.
Y2K SS
06-21-2005, 10:06 PM
ah shit. So your saying when I put in my gears I'll have to shift to 5th with what I have below??
BGImportkiller
06-22-2005, 08:15 AM
You can get taller tires too. I have all stock internals and am going through the traps at like 6000 at like 107. Next year I am going to get some 28" slicks, and that should take care of it.
LS1TORQ
06-22-2005, 08:12 PM
I read this in PHR, They dynoed a crate LS1 and the valves floated pretty bad at 5,800 rpm. They then put in the blue LS6 vavlesprings and the engine could wind up to 6,600 before the numbers fell again. The engine peaked at 6,400 rpm with 454 hp while carrying over 450 hp from 6,000 rpm to 6,500 rpm. Torque was still 372 at 6,400 rpm. Just from swapping springs the engine made 30 hp and 30 lb.ft at 5,900 rpm due to stock springs floating. So what I'm thinking is to get my 4.10's, put in probably 918's with titanium retainers and bump the rev limiter to 6,500 and the stock cam should still pull according to this article and be much better off going through the traps at 115 plus.
LS1_PNYTAMR
06-22-2005, 09:06 PM
well im running 4.10's and plan to clear the 1/4 with a much bigger cam and 150+ shot...... just gonna run 28" tires
