major ZEX kit problem
just got my dry kit installed on my LT1 and got the bottle filled yesterday. Last night I tried it out, and when the nitrous is injected, the car basicly just starts sputtering and you can feel the nitrous working, and then stopping... just surging and not having a constant flow. I also hit it from a stop once... and the car backfired really bad, and my service engine soon light came on right away... I thought I was without a motor, but it's still running fine but now I'm afraid to try it again. My intake duct elbow is ripped a little on the bottom... that's the only thing I know that's wrong with the car itself...
What type of plugs are you using? I am not sure about the LT, but in the LS1 you need a copper plug in the Ngk tr6 range, also gapping the plug is important. Also if you have one, check your fuel pressure safty switch, it might need a little adjustment.
if you dont have a colder plug, it would have somethign to do with it, for the lt1, you definatelly wanna get a colder plug, also your optispark ignition could be shitting out too.
Originally Posted by Magic Chicken
should've kept the NOS kit. a new set of plugs is cheap. if you don't have a fuel pressure safety switch (fpss) you NEED one.
plugs are cheap, but not fun to install
everybody really think's its plugs on a car with 30k miles... and like I said I'm pretty sure the plugs have been changed for nitrous
sounds like a bigger problem than plugs to me.. What rpm are you spraying at? are you trying to spray with that hole in the intake tube? have you checked for proper fuel delivry? Maybe your pump isn't strong enough, but it definately sounds like something more than plugs
wow, found the problem for sure I think
I took out 3 plugs... 2 of them completely had their tips broke off, I don't even see how they were getting spark! And they ended up being the stock plugs... previous owner lied to me about having nitrous plugs in it...
LOL...geeee, ya think that might have something to so with it??!?!?! i would have guessed the same thing...but more so the nitrous was just blowing you plugs out...never thought they'd be that bad.
Originally Posted by 94camarof1
almost funny
im sorry...wasnt tryin to be rude. but you have to see it this way...you could've seriously destroyed your engine over a set of $20.00 plugs. and you didnt, so you have to laugh it now.
Got the new plugs today... thanks for everybody's help.
