150hp Shot On Bone Stock Ls1
Old 06-17-2005, 10:03 PM
Racer
UL LOSE's Avatar
Default 150hp Shot On Bone Stock Ls1
bout to be sprayin a 150hp shot of nos courtesy of TNT nitrous kit. would just like to have everyone give me some fore warning or suggestions. installin the kit tommorrow. let me know of any and all problems you all have encountered. like to know exactly what to expect. my car is an o2 ws6. engine is bone stock. any help would be appreciated-josh
Old 06-18-2005, 02:29 AM
DONAIMIAN's Avatar
Follow the directions and make sure your fuel system can handle it. Also you might want to start off with something smaller instead of just jumping into a 150hp gain. Make sure yo have the right plugs and log all your runs to make sure you dont run into any detonation.
Old 06-18-2005, 02:36 AM
20firebird02's Avatar
my dad is running a 150 nx shot on his and is bone stock. had not had any problems and the kit has been on for over 40k. the only thing that he changed was his plugs.
Old 06-18-2005, 03:31 AM
ws6sojuiced01's Avatar
get some ngk tr6 gap them to .038, and i would do a fuel pump if you havent yet.
Old 06-18-2005, 11:07 AM
Slart's Avatar
I know this is obvious, but you're asking for advice and you know I cant refuse
The two major concerns are going lean or activing it at too low an RPM (or leaving it running at too high an RPM). The standard precautions against this are a fuel pressure safety switch (to keep it from going if the fuel system cant keep up), and a window switch (to keep it from activating at too low an RPM or staying on when you shift).
A better (Ie, even safer) solution than a FPSS would be a NX Maximizer, because it watches your O2 sensor instead of the fuel pressure, so it's more of the "bottom line" regarding whether you're lean or not. IE, the FPSS wont protect you from a faulty solenoid or crap in the fuel line, or if the nitrous pressure is higher one day than when you tuned it.
The NX Maximizer also works at a window switch.
Old 06-18-2005, 02:07 PM
Racer
UL LOSE's Avatar
So he didnt change his fuel pump or anything? No window switch? No FPSS? Thats suprising. I plan on all those within a week or two. Ill probably jet a 100hp shot first then ease my way up. Just in case. thanks 4 da help-josh
Old 06-18-2005, 02:11 PM
Racer
UL LOSE's Avatar
Ok this may be an idiotic question but can you not spray throught the gears in an auto with a 3000stall? I wont be sprain til 2nd gear.
Old 06-18-2005, 06:26 PM
BigSmallBlck2GZ's Avatar
Im Spraying 150 Now And All Last Summer, My Z Takes It Like A Champ....jus Did A Plug Change, Thats It. Jus Keep Up On Regular Maintnance And Oh Yea, Try Not To Hit Your Rev Limiter Or Mis Shift If Its A Stick....my Buddy Decided To Do A Nitrous Burnout Last Summer And Burned A Valve, But He Still Smoked The 03 Cobra With 500 Horse With No Problem....
Old 06-19-2005, 03:02 PM
69_YENKO's Avatar
im also curious, i thought an auto could be sprayed through the shifts
Old 06-19-2005, 03:12 PM
b00sted's Avatar
If it can handle the power, sure. Anti-balooning converter, shift-kit, bands and clutches that wont slip....The trans has to be able to hold however much hp the car will make on spray.
Old 06-19-2005, 04:34 PM
Slart's Avatar
With the stock trans, I dont think it will take 150 through the shifts. Mine couldn't even take the engine's full power. The stock PCM tune removes several degrees of timing on shift to keep the trans alive. When I disabled this safety function my trans started slipping on the 1st->2nd shift.
This safety function probably pulls about 40 ft/lbs at most. You're talking about adding 130 ft/lbs at your shift point (150hp @ 6000 RPM is 130 ft/lbs). Based on my experience, I dont think the stock trans will take it. Who knows, maybe my experience is not typical and others will chime in.
You can definitely improve the trans to where it can take it, but I assume you dont want to do that.
If you put a window switch in you can set it to stop spraying just before the shift and start again in the next gear. This will help a lot. Unfortunately, a typical window switch isnt smart enough to do this right and it'll start spraying before the trans is done shifting. Might work fine, might slip.
Once again, this is where a controller like the Maximizer has big benefits. You can program it to cut off before the shift, then wait a short time (.2 sec) before it reengages in the next gear to give the trans time to complete shift.
Old 06-19-2005, 04:50 PM
eric01ss's Avatar
make sure u do every thing right the first time and not the second time
Old 06-19-2005, 07:23 PM
Kjanks's Avatar
I have a 2004 gto and I was talking to my dad about doing nitrous. What would be the best thing to go with?
Old 06-19-2005, 08:02 PM
gollum's Avatar
Those nitrous/fuel jets are real small and easy to clog. Make sure to keep everything clean and blown out before connecting lines to nozzles.
Old 06-19-2005, 08:33 PM
slick1851's Avatar
Spray the ever living **** outta it ls1s eat them up
Old 06-19-2005, 09:56 PM
yes he has a window switch. set between 3000-6200 rpm. no other changes except plugs have been changed. hell he jst got cut-out/ magna flow catback like 5k ago.
Old 06-19-2005, 10:30 PM
SDB
SDB's Avatar
I have a NX wet kit on my 2004 GTO and love it...make sure to get it dyno tuned, my car was super rick and popped and even had a fuel backfire before we got the jetting sorted out. Before tuning, drag radials, and computer mods, I ran 12.5 @115 with just the bottle....should be bottom 12's at 118 or so I would imagine.
Old 06-19-2005, 10:54 PM
LS1_PNYTAMR's Avatar
150 shot is fine on a bone stock car... i did it many times... fuel pump should be okay.. swap out to some tr6 plugs.. also, expect 150rwhp or more
Old 06-20-2005, 11:25 AM
Kjanks's Avatar
Default Tuning?
So, I have to get this thing dynoed? Do I need drag rads? And should I put the loud mouth exhaust on it with electric cut outs?
Let me know
Old 06-20-2005, 12:53 PM
calongo_SS's Avatar
A tune is a good idea, but you should be ok on the stock tune. If it were my car, I'd get it tuned. The exhaust is not really going to be crucial but I wouldn't put a LM and a cut out. One or the other would be fine.
Quick Reply: 150hp Shot On Bone Stock Ls1
