Building a Very Strong and Reliable FI Motor
I am in the process of getting a F1R supercharger kit. I would like to be able to max this out, but I need to know what parts are suggested for this task. I know Eagle is most likely not up to the job, but how much is too much by wasting money? I mean do I really need the $1800 Billet Rods and $3000 crankshaft? I want this motor to take a beating and not worry about doing teardowns once a year.
how much boost do you plan to run? and what are you horsepower goals? if you are looking for say 600-700rwhp Eagle would be fine as would the Callies rods, if you plan to push 1000rwhp then I would step up to Callies crank and Oliver rods. it all depends on your goals. it can get expensive very quickly.
I have a great 370 cu in FI shortblock I'm selling, It will handle whatever you throw at it. I have it in the for sale section, you can look it up by my user name. Let me know if you are interested. Thanks Dave
Well, since I want to max out this supercharger (1300HP) I will take you suggestion on the rods and crank. Any preferences on the piston manufacturer and/or rings? Any opinions on Total Seal Max Rings? I am also thinking about intergrating a vacuum pump to help the rings seat better with the forced induction.
I asked the same question. Here is the link to the thread https://ls1tech.com/forums/forced-induction/336858-block.html
Hope it helps
Hope it helps
This is what futral sent me when I was asking similar questions.
I deleted pricing. If you want prices ask futral or send me a pm. They are VERY reasonable
Forged 347 shortblock up to 20lbs boost:
-bore\stress hone\deburr\clean block
-race prep stock crank
-Manley sportsman rods
-Diamond dish pistons
-total seal rings
-Federal Mogul bearings
-ARP main studs
-balanced\blueprinted\assembled
For 20+ boost add **** for custom pistons and Hellfire rings.
**add ****** for block\crank core if needed.
-add for blower cam
under 20 lbs 236\243-114
0ver 20 lbs 239\250-114
For a FI setup get a set of AFR 205's for under 20 lbs boost and the 225's for 20+ boost.
AFR 205 with shortblock
AFR 225 with shortblock
Stuff t0 finish longblock.
-Melling lifters
-lifter trays
-ARP 12 pt head studs
-GM MLS head gaskets
-Rollmaster double chain
-FMS ported oil pump
ATI DISC intercooled race kit
-total seal rings
-ARP main studs
-add for blower cam
-Melling lifters
-lifter trays
