Swapped on truck pan
Moderator
I finally swapped on the truck pan I got off Yank's
garage sale a while back. It replaced a TCI chrome
pan which I never got to seal right. The TCI cork
gasket disintegrated when I took it off. Cork gaskets
should just be discarded. I had originally picked up a
trans filter and gasket kit at Advance telling them
for a 1500HD SIlverado. This was a mistake, I ended
up with a TH400-looking pan gasket and a stumpy
filter. The HD designation means 4L80E. If you do this
pan swap, get the kit for a 2002 Silverado 1500 with
the 5.3 motor. This filter is 1" longer in the neck than
the regular ones. I put this on and it all fit good with
no more leaks. It took 8 quarts of ATF to fill up the
deeper truck pan.
This pan is deeper but the lowest point is still my
Y-pipe. It's 1" shorter than the finned TCI super-deep
that I was dragging and its drain bolt is flush, so I
am hopeful that it'll be my last pan swap.
deeper truck pan.
Thanks for the good info. I'm planning on getting the truck pan as well. Unfortunately, they don't make it with a drain plug anymore as others have mentioned already. You got lucky getting one of those older pans with a plug. I guess GM figured it was better job security for the GM techs by omitting the drain plug on the newer pans. I was going to order a truck pan with the drain plug installed from http://www.4l60-e.com I think it runs $62.00 w/plug.
