Better gas mileage after headers?
Old 06-30-2005, 05:52 PM
fivepointseven's Avatar
Default Better gas mileage after headers?
Is this even possible? I swear in my case it is
Old 06-30-2005, 06:05 PM
KrazyDan's Avatar
id say with the better air flow its possible. But in my case it is not possible because i like to listen to the roar too much .
Old 06-30-2005, 06:09 PM
LS1Adam's Avatar
my gas mileage went waaaay downhill after the header/dual install. its definitely worth it tho just to hear that car rev up and fly. maybe after a tune it'll get better. You are one lucky guy to have better gas mileage now after the install
Old 06-30-2005, 06:42 PM
SmokingWS6's Avatar
Mine went up. Scans showed it was running lean, after I tuned it milage stayed the same as before the swap.
Old 06-30-2005, 06:59 PM
Cody Brooks's Avatar
shouldn't change much if any.
Old 06-30-2005, 07:30 PM
SSU's Drunk Typing Whore
Lithium's Avatar
it should go up a little with a good tune. But mine has definitely gone down, I just cant seem to keep my foot from going to the floor.
Old 06-30-2005, 07:49 PM
Coy
Coy's Avatar
LS1Tech 10 Year
mine was down pretty bad till I deleted the air, then it improved slightly. (better than stock)
Old 06-30-2005, 09:18 PM
BlueSix's Avatar
In theory is should go up. The engine is working more eficiently than it was before....that should increase mileage. I know that Nine Ball said his ols SS vert got better mileage after the heads/cam since everything was working more efficiently....Colonel said the same about his H/C Z28.
Old 06-30-2005, 09:30 PM
SLPCAMAROSS's Avatar
its possible.. not common
Old 06-30-2005, 09:41 PM
rush7's Avatar
mine went in reverse...dropped from about 20mpg to about 15. My PCM was dumping a lot of fuel when I scanned it. The weird thing was I put on an underdrive pulley and got my 5mpg back. It's been hovering around 20 ever since and my PCM dumps less fuel (I still need to have it tuned though)
Old 06-30-2005, 09:44 PM
blkZ28spt's Avatar
If you have it tuned, or the air/fuel ratio just happens to be good and you drive it the same you should see slightly increased gas mileage. Maybe not anything you notice, but it should get better.
Mine didn't.
Old 06-30-2005, 09:58 PM
badSol's Avatar
For some reason, I get a good extra 2 mpg or so after my header/dual install, but some of that is likely attributed to the new plugs.
Old 06-30-2005, 10:05 PM
Frosty's Avatar
I'll tell you next weekend
Old 06-30-2005, 11:30 PM
2000slpss's Avatar
when i put my headers and true duals on my mileage improved by 2 mpg on average. thats without a tune
Old 07-01-2005, 05:45 PM
DWillTA's Avatar
I have headers and true duals. My mileage, the best I have seen, is 22 mpg. That is with a mix of in town and interstate running. I think if anything I have stayed the same. If I run the car hard I can still get 17 mpg. My Ltrims are in the +5% range. Strims are around 3% to 6%. So I am alittle lean but not to bad for no tune.
Old 07-02-2005, 03:23 AM
DONAIMIAN's Avatar
You reducing backpreasure so it should go up, but with most it dosent becuase we romp on it a lot more because of the new found sound. Also heads will improve gasmilage because of better efficency in the burn of the A/F mixture.
