uh oh, broke the dang oil temp sender...
well i drilled and tapped the piece above the oil filter, went great. put the sender from auto meter in there and its pretty long and i guess i went a little deep with the tap and it snapped the end off. so im getting really sparatic readings on the temp gauge for the oil. does autometer have a shorter 1/8" sender? if anyone knows, or a way that i can fix this and get a new sender? i was worried about drilling and tapping and i mess the easy part up lol
hey what did you connect the "igniton wire" to on your autometer gauge, i just got the same one and that is one of the 3 wires i need to hook up, the others are ground, and the sender. is the "ignition wire" just a constant or switched 12 volt source?
