How to remove headlights?
Does anyone know if there is a thread in here somewhere that illustrates how to remove headlights on a '00 Camaro? Or, can someone just post the info?
I've looked at them and if you look at them with hood popped you should see the bracket that holds them in.. should be a 10mm like everything else.. upbolt everything you can visually see and then tug on the light.. feel for tension.... but these lights should be cake to get out compared to a T/A and I can pull mine in less than 5 mins...
