Is a small clunk normal for 4.10s?
Old 07-05-2005, 08:39 AM
BADSZ28's Avatar
Exclamation Is a small clunk normal for 4.10s?
I recently installed 4.10s in my 10 bolt and the measurements were to specs. When I first pull away I get a small clunk in the rear. I think it is just the rear taking away the lash in the trans and rear as I pull away and is just amplified by the 4.10s. Is this a posibility? Is this normal? Only does this in a forwad gear, not reverse. If something were loose, I would think it would do it in reverse too. I have put a few 100 miles on it with no problems, including some hard launches. They do wine, but not tearibly.
Old 07-05-2005, 11:37 AM
LS1s R US's Avatar
Try some royal purple 75-140 It has quietend a few rears down I have serviced. Also check your trans mount and tourqe arm mount for any damages.
Old 07-05-2005, 12:36 PM
BADSZ28's Avatar
Thanks for the responce. Checking the torque arm and trans mount is a good idea. It feels more rearword though. But I will check. I am taking the car to the track tonight with some stickies, so I just want to be sure everything is good.
Old 07-05-2005, 01:06 PM
LS1s R US's Avatar
yeah I have also seen u-joints go dry and chew themselves of and pop only under a load!
Old 07-05-2005, 01:28 PM
BADSZ28's Avatar
No good news comes from you huh? LOL. You are making me nervous. I will have to look more closely. I am hoping it is just the gear taking up the lash.
Old 07-05-2005, 01:41 PM
LS1s R US's Avatar
Na I just work on lots & lots of these cars most of the higher mileage car have the most wore parts say 100k.You will hear a little clunk with 4.10s and a little more if it is a M6.All ya can do is run it till it breaks. My A4 car I have runs mid 1.50 60fts with the 10 bolt 3.73 motives & TA girdle!I have become used to a little noise!Just look it over good and If ya don't see nothing give it he!!.
Old 07-05-2005, 02:16 PM
BADSZ28's Avatar
Thanks man. I really appreciate your wisdom with this. My car only has 28K with a fully built 10 bolt so I should be OK. I do have an M6 too. I also have a line lock to pre load it, so I think I should stop sweating.
Thanks Again!
