Which progressive controller?
Hey guys,
I was looking at the NX "2 dial" progressive controller for my nitrous system, but after some tests, I guess it won't work w/ the larger solenoids.
So, what are my options? I have a NX single spray bar plate kit, efi fuel pressure, and my FAST ecu is controlling the ground side of the relay.
I was looking at the NX/FJO dual window switch and getting the driver for progressive control but I don't need all that stuff. I don't need the TPS control and window switch since my FAST already does that. After looking at the FJO instructions, it looks like you can change the ramp time from 0 to 100%, but can not adjust the starting percentage, which is important.
Would this work?
http://shop.store.yahoo.com/hm-perfo...edprnico1.html
Edelbrock says that each solenoid can be up to 45 amps, where the N*S controller can only handle 10-15amps for the solenoids.
