Which parts necessary for a big cam?
Old 07-10-2005, 04:51 AM
donscheffler's Avatar
Default Which parts necessary for a big cam?
Hello,
I'm planing on adding a big cam.
Something about 230/236 114LSA.
I already have stock Thunder Rcing length pushrods, ti-retainers and single valve springs.
I think off adding dual valve springs, hardended seats and valve stem seals.
Anything else I should consider?
Any brands to recommend?
I will spin the engine to something about 6.700RPM.
Thanks
Olli
Old 07-10-2005, 10:03 AM
conan's Avatar
Double roller timeing chain, ported ls6 oil pump, gasket set, crank bolt, and oil pump O ring.
Old 07-10-2005, 02:02 PM
JZ'sTA's Avatar
Add a converter to that list as your ganna need something larger to match the cam nicely.
