Cam install extras?
Cam install extras?
I have a 00 ta with about 44k miles and I am wanting to install a hot cam. Should I replace the oil pump and timing chain or is it not necessary.
Any help would be great.
I would do a ported LS6 oil pump, front main seal, and LS2 timing chain. You don't need valve cover gaskets, front cover gasket, and you can even get away with re-using your water pump gaskets (Replace anyway to be on the safe side).
That's what I did.
