Do Moser's use gaskets?
Getting ready to change my rear diff. fluid and was wondering besides the 3 qts of 75w 90 fluid and gm additive, do I need to buy a gasket or can i simply use something like Permatex sealer? TIA. Also, I will have to drop at least one side of the panhard bar to make room to take the diff. cover off right?
LS1TECH Sponsor
Yep, it's a standard 12 bolt gasket. I use gasket sealer on both sides of the gasket and do not get leaks. I have not had to drop the PHB to change fluid or gaskets before. I also have the TA cover.
Thanks for replying guys, and that's exactly why I asked. I've heard some people say to use a gasket, some say use gasket and sealer, then others say use only the RTV sealer. I suppose all will work. I think I'll use the sealer only, but figure once I apply it to the cover, I should let it dry to form a gasket, and once dry bolt it back up. Is this right?
