A4-M6 questions
A4-M6 questions
Alright guys I read all of the sticky & still uncertain about a couple of things. I have a 99 A4 & will possibly be getting a 98 6spd. I know I will need all the basics, clutch, trans, flwywheel, tourque arm mount, master cylinder, slave cylinder, shifter, console & etc. My only 2 concerns are Would it be easier to swap the wiring harness in the swap or keep the one I got & modify it? Also will I need to swap the torque arm? Or can I just swap the mounts?
Thanks,
Vann
Thanks,
Vann
I changed the harness, but only because someone was willing to swap with me. The haness wasn't hard to swap, but modifying the A4 harness isn't either, so either way. M6 harness is just cleaner. Should only have to swap the TA mount.
I modified my a4 harness and it wasn't hard at all. Your driveshaft and torque arm will work, you just have to swap the torque arm mount. Shoot me a pm if you have any more questions. I did the swap about 6 months ago and everything works great
