how do I get flywheel off
Haahahha...pry a little(carefully) with a large screwdriver or pry bar. You'll have to pry around the edges then maybe spin the flywheel around and pry some more to get it off. You have to sort of "wiggle" it off. It fits on there tight.
ok um I got a big pry bar and hit it with a hammer, still not even a little wiggle.
http://www.914club.com/bbs2/index.ph...T&f=2&t=34592&
I don't think that roll pin should affect you getting it off. It's probably just stuck on their good and will take some constitent and difficult prying with a crowbar, working slowly around the edges, to get it off.
Did you ever get the flywheel off? If not, use a rubber mallet and tap the flywheel all the way around the flywheel. Mine took awhile to get off also. I turns out that it was just siezed to the engine and took abit of mucsle to get it off. Keep trying - it will come off. Btw - it is fairly heavy - dont let it hit you in the head or ribs.
