Autozone Power Antenna
Bought this replacement a couple of months ago and it worked fine initially. Then it started to work intermittently. I found a short. I fixed that and it was working fine. Now it's not working at all. Got a replacement from Autozone. Want to make sure I have it wired correctly.
I have the blue wire from the antenna connected to the green wire from the radio. And the red wire from the antenna connected to the orange wire from the radio. Black to black.
Anyone have this antenna and is this wiring correct?
Is there a replacement antenna like the stock one, but doesn't have the foot long support inside the trunk? Just something that clamps onto the fender directly, but has proper angle mount?
Originally Posted by PSYKOZ28
the wires are correct from what i did and mine works.
and is the antenna chrome or black, the only ones Ive seen were chrome (want black)
BigSteele, Click the link below, the top pic is of it installed.
It's the write up I'm going to use when I do mine...
Camaro Power Antenna Install
