lpe gt2-3 if you have one come in please.
I am wanted to get this cam for my mostly stock car and want to know if the pushrods should be stock length 7.4 or if i need something longer??Also let me know what springs you guys are running with this cam.Ls6 springs just dont sit well with me but lpe says they work good.give me your input.thanks
decided to go with comp 918's just because they are a very good spring from what i read and the guys at lpe said they would also work if i didnt want to use the ls6 springs,just costs more.does anyone know if the titanium retainers they recommend will give me an installed height of 1.8.thanks guys
Originally Posted by 99ssleeper
I used my stock pushrods and bought the Manley 1423 spring kit from SDPC2000.com for $179 which icluded Ti retainers. All worked well for me.
same here
I went with 918's and chrome molly 7.425 pushrods. Unless you have the LS6's longer valve stems, you need to increase the PR lenght to keep the lifter preload at the proper value, compensating for the smaller base circle of the LPE cam.
let me know what length pushrods you guys are using .I called lpe to find out what the base circle on the cam is so i could figure it out myself but they dont know that measurment.My motor is stock and i dont think the 7.4's would be correct with that lift on the cam.
See my previous post. 7.450 might be o.k., but to play it safe, 7.425. And I intend to dyno my car after the cam swap, but it will be a few weeks yet. The only change will be LPE cam and an underdrive pulley.
yeah i will use the 7.425 length just because i know 7.4's wont give me the stock preload.I know there is no way the base circle on the gt2-3 is the same as stock so i will definitly use the longer ones to make up for it thanks guys.
I know what lpe says it probably puts you in the .030-.035 preload range which is still ok but i want the factory preload settings of .050-.060.I rather keep the factory preload than what lpe says will work.
