Key Fob Programming???
Key Fob is all messed up, wont lock the doors, wont open the trunk, and barely opens the door. Its apparent I need a new fob. Checked with the dealership and itll cost me over $120 to get the fob and have it programmed. Is there any other way I can get this done without getting raped by the dealership???
Before doing that.. try holding lock + unlock next to the car it will try and sync with the car without doing that ****
http://installuniversity.com/install...ar/key_fob.htm
Originally Posted by chevymec
Might wanna try and pop it open and clean the contacts in there. Just take a pensil eraser and clean them. Alot of times they will get gummed up and cause problems.
Originally Posted by shouldaboughttheZ
Not a good idea. As the water will cause corrosion later on, and you will REALLY need a new fob.
