Dyno'd TNT Kit, 150 shot on 123,xxx mile LS1
Old 07-20-2005, 03:22 PM
TINKRD's Avatar
Default Dyno'd TNT Kit, 150 shot on 123,xxx mile LS1
FYI on the car: 12bolt w/ 4.10 gears and 123,5XX miles on the odometer.
After some tweaking she put down:
Motor
391.3 HP and 369.1 TQ
A/F 12.6-12.7
Juice-150 shot
555.4 HP and 562.1 TQ
A/F 12.0
She's driving great and pulls hard. I'll post up a graph tomorrow.
Everyone was amazed at the HP #'s for such a high mileage car.
She's doing great.
Track times coming Aug 19th.
Old 07-20-2005, 04:17 PM
tntws6's Avatar
Nice numbers, I bet she is an animal.
I have a couple of questions that would be very helpful to myself and a few others.
1. Are you using 93 octane?
2. What was the total timing value for this dyno run in degrees of advance BTDC?
Old 07-20-2005, 04:46 PM
MDoe8's Avatar
cammed? what are you running as far as fuel goes?
Old 07-20-2005, 05:17 PM
cantdrv65's Avatar
Cool
When I sold my 99 Z28 it still pulled like a raped ape on the TNT 150 shot with 114,000 miles.... Tuning is the key to longevity with N2O.
Old 07-20-2005, 06:53 PM
TINKRD's Avatar
thanks guys,
timing on the cam is set at 26 degrees, (did that answer your question?)
93 octane gas as well. I'm running the G5X3 114lsa cam.
Old 07-20-2005, 07:46 PM
setxws6's Avatar
Makes me feel good about trying out the 150 on my 2002 with 55,000.
Old 07-21-2005, 10:08 AM
David@TNT's Avatar
Motor
A/F 12.6-12.7
Juice-150 shot
A/F 12.0
She's doing great.
What do you have for a fuel system??
Old 07-21-2005, 10:27 AM
InsomZ's Avatar
congrats! very nice car.. go get some track times! i'm curious what she'll do
Old 07-21-2005, 12:55 PM
LETZ RUN's Avatar
im gonna spray my 95k motor w/ new cam and such w/ a tnt 200.. i hope i can get the tune good enough to make it last a little while, if not, atleast it'll be fun.
Old 07-21-2005, 12:59 PM
V8_DSM_V8again's Avatar
Use a wet kit and start fat on the fuel then lean a bit...
Old 07-21-2005, 01:43 PM
TINKRD's Avatar
Racetronix plug-n-play fuel pump kit.
Old 07-21-2005, 01:58 PM
TINKRD's Avatar
i'm getting the graph scanned this afternoon and will post up
Old 07-21-2005, 02:38 PM
TINKRD's Avatar
As promised
Old 07-21-2005, 02:56 PM
mike c.'s Avatar
when you spray does your A/F drop to 12.0 on its own or did you do something to make it drop? t.n.t told me A/F should be in the low-11.2 11.5 A/F on their kit. any in put on this?
Old 07-21-2005, 03:25 PM
TINKRD's Avatar
A/f does it on its own. This is a wet kit, therefore the computer doesn’t even know what’s happening b/c it’s spraying behind the MAF.
Old 07-21-2005, 03:52 PM
Turo's Avatar
Nice numbers! What was your bottle pressure at?
Old 07-21-2005, 04:04 PM
Ravenous T\A's Avatar
Damn I basically have the same mods you do I can't wait to go and get mine done seeing yours being able to do it makes me feel a whole lot better about when I take mine
Old 07-21-2005, 04:31 PM
LETZ RUN's Avatar
is it just me or is his NA a/f lean?
Old 07-21-2005, 05:34 PM
TINKRD's Avatar
Bottle pressure was 950-1000 psi
Old 07-21-2005, 07:25 PM
Tiger2o69's Avatar
wow.. I would have thought that was a bit rich.
Quick Reply: Dyno'd TNT Kit, 150 shot on 123,xxx mile LS1
