ignition problem
Old 07-20-2005, 03:42 PM
dtpracing's Avatar
Default ignition problem
Here's one for you ignition gurus. I have an ticking/arcing sound coming from coil #3, when you run a cylinder test on EFI Live when it tests that cylinder the ticking/arcing noise momemntarily goes away.
I have replaced the spark plug, no change, replaced the plug wire, no change, replaced the coil, no change.
Any ideas?
Thanks
Old 07-25-2005, 06:11 PM
WILWAXU's Avatar
Where is it sparking off of?
Old 07-25-2005, 07:40 PM
89lx-ls1's Avatar
I couldn't even begin to guess if you have changed everything????????
