Timing issues
Old 07-21-2005, 02:55 PM
Public Enemy's Avatar
Default Timing issues
My timing at WOT is 0 advance when i checked it with EFIlive.. i dont get it???
The car is 2004 pontiac gto A4 , full-bolt-ons and cam,
when i checked the high octane table everything is fine? what is the problem?
Old 07-21-2005, 02:56 PM
HumpinSS's Avatar
log all the other timing tables and see where it is pulling all the timing from. Also burst knock could be a culprit
Old 07-21-2005, 03:09 PM
which timing tables? all of them looked fine to me
Old 07-21-2005, 03:16 PM
HumpinSS's Avatar
the timing tables in the scanner not the editor
Old 07-21-2005, 03:29 PM
yeah, in the scanner it showed timing goes to negative
but in the editor everything looks ok
Old 07-21-2005, 03:34 PM
HumpinSS's Avatar
there are 22 timing pids located in the SCANNER have you tried loging them while driving. On decel timing will go negative when dfco is active
Old 07-21-2005, 05:05 PM
gametech's Avatar
What do your IAT's look like? The gto has a very aggressive timing retard for high IAT's.
