Bad spring causing cam sensor code?
Old 07-27-2005, 08:39 AM
robertbartsch's Avatar
Default Bad spring causing cam sensor code?
About a year ago I got a bad cam sensor code and, after replacing the cam sensor with an OEM unit the cPCM odes did not reappear.
After a new PCM was replaced last week at the GM dealer, however, they now tell me the car is throwing a bad cam sensor code.
After thinking about this awhile, I suspect it may be a broken valve spring that is causing the cam sensor code to go off.
Any thoughts here?
Thanks
Old 07-27-2005, 08:44 AM
HumpinSS's Avatar
You sure it is the cam sensor code and not the Crank sensor relearn code...
Old 07-27-2005, 08:56 AM
the GM dealer tells me it is a cam senor and not a crank sensor code?
Old 07-27-2005, 03:07 PM
weird hey?
Old 07-27-2005, 03:22 PM
horist's Avatar
if you have a broken valve spring you'll hear it... I would find someone that can do a crank relearn procedure on the new PCM and see if it goes away (anyone w/HP Tuners or EFI Live can do a relearn)
