Sponsored by: DashLynx
Need halo wiring help....
Old 07-29-2005, 07:21 PM
SSNISTR's Avatar
Default Need halo wiring help....
I just wired up one of my halos. I ran the red wire to the purple fog light wire, and ran the white wire to the radiator support for a ground. Didn't work....so I changed the ground to the other fog light wire....still don't work? I used those little wire blocks that you put the wires in and close them up and they crimp down. Was that the problem? Do I need to do something instead? I am kinda lost as to what I did wrong, wiring seems good. Any ideas? How exactly did you all wire them up? Thanks!
Old 07-29-2005, 07:42 PM
SSU's Drunk Typing Whore
Lithium's Avatar
huh? thats wierd. I just installed mine and did the same thing and it worked for me. When you gounded the white wire did the lights come on at all?
Old 07-29-2005, 08:24 PM
SSNISTR's Avatar
Nope, nothing......maybe I just need to check the connections.
You used those same kinda connectors?
Old 07-29-2005, 08:31 PM
AW/whiteZ-28's Avatar
Sometimes those connectors don't cut all the way down to the copper. Try pulling a little insulation back, then connecting the blocks.
Old 07-29-2005, 08:39 PM
Ell Ess Won's Avatar
What's not working? The headlights or the Blue halo's themsleves? You CANNOT see the halos during the day. make sure you connections are good and twisted straight.
Old 07-29-2005, 08:44 PM
Lithium's Avatar
Yeah. Also make sure that the metal thing is down all the way. Otherwise it wont work.
Old 07-29-2005, 08:57 PM
SSNISTR's Avatar
The halos, the headlights work fine.
I'm gonna make sure the connectors are fully crimped tommorrow.
Thanks so far for the help guys.
Old 07-29-2005, 09:58 PM
Z28LS1camaroguy's Avatar
did u also make sure that the halos worked before you did all this, bc you should always test them before you go through all the trouble of wiring and stuff. but as for my halos i just ran them to an independent switch and they work fine, grounded them to the bolts on the fram right next to the air intake.
Old 07-30-2005, 09:11 AM
68ss_00ss_87_95's Avatar
i wired mine to the same wires for the fog lamps and they turned out fine...just my .02
Old 07-30-2005, 11:39 PM
94redz28's Avatar
Make sure your fog light switch is on.
Quick Reply: Need halo wiring help....
