check this engine out!!
ok well on monday im deleting my a/c and im curious as to what pulley is directly under my A/C pulley? and does anyone have an idea as to how big of a replacement belt im going to need??? and its a 350 5.7L power everything
heres a pic....
heres a pic....
Its the Power steering. You should already have two belts, one just for the power steering and one for the A/C & P/S. Just take a string and loop the Crank, water pump, and P/S and measure that for a rough Idea. Do it with the P/S full down on adjustment (loose belt) and full tight (Tight Belt) to know the range you need to be within. I wish I remember the belt to use.
