Help with ideas on how to rig exhaust so I can make it to a shop
I clamped my original i-pipe to my TSP ORY after my H/C install. Well, the flange for my cutout is maybe 2" off the ground so it's a major issue. Well, I thought the clamp was good/tight enough to get the job done. The pipes it holds are maybe 1-1/2" apart so it's not clamping on much, but I thought it was enough.
Took it for a spin saturday evening for the first time.... must say it was incredible even though i'm relatively untuned still. It was dragging the cutout flange a lot in the neighborhood even on small bumps. Well, check it out once I'm back in the garage and it came undone, basically the flange caught and pulled the whole muffler and everything back enough to pull it from the band clamp.
Any ideas on what I can do to get this thing to a shop? I don't want to risk it really grabbing something and tearing the **** out of my car.
Thanks,
Dennis
Thanks,
Dennis
I can run it open and have...... problem is since the i-pipe isn't connected it wants to rock forward on the mounts making for even worse ground clearance and a serious hazard. If that pipe which is tilting down towards the ground catches something solid........ buh bye who knows what.
The tin can idea is basically what the band clamp I used was trying to immitate. The band clamp I used was 3" wide but there's enough slop in the hangers for the muffler and i-pipe that it pushed back and slid out from the clamp.
I had a clothes hanger on it at first, but it bumped the ground and got wedged up higher than it started with when we tied it off. It made the pipe rub the drive shaft and that's a big no no. Luckily I heard it right away and basically just polished a small ring around the drive shaft.
I'm thinking I may have to cut the over the axle pipe and pull the muffler and everything back there off and get it to the shop that way. Looking for other ideas though. Keep em coming guys.
Location: Live Oak, FL - in the woods where the creatures lurk.
So basically what you are saying is, you installed an ORY & everything didn't match up? And you are trying to get to an exhaust shop to square things up. I'm not underneath my car right this very second ( ) (have been today) but just try to wire that sucker up with some coat hangers, wire or something and drive carefully. I know it sucks when things don't go right, but just think it out.
Gerald
Gerald
