Changed factory plugs to TR55s now Gas Mileage SUCKS!
Well, I have 46k on the clock so I decided to change my plugs. They were the factory Denso Iriduim pieces. While I was in there I noticed I had some burns/chaffing on 3 of my plug wires. So I got some Autozone Bosch factory replacement and NGK TR55. I gapped the plugs to .50 as most people recommend here. Well, I USED to be able to get 240+ a tank in city. Now I am BARELY getting 200miles to the tank.
WTF? Whats going on? I dont have any codes. I drive pretty conservative. My mods are in my sig. I've had all these mods for quite some time now. Anybody have any input? Thinking about going back to the Denso factorys. Hell, I might even put my old wires back on.
Thanks.
Very frustrated Ski
Thanks.
Very frustrated Ski
I changed to NGK's and noticed a drop in gas mileage also. My gas mileage has always sucked though, but I cant complain. I love my car. But if you find out the plugs are causing it, let me know and i might have to switch mine back.
LS1Tech Administrator
Received 1,794 Likes
Never seen a drop in mileage going from stock plugs to TR55s on any of my LS1s....
Well, its not the wires. checked those. one thing i have noticed is my "tick" has become louder. Leaning more and more towards collapsed lifter. Heres my dilema. I have to move at the end of this month. I can limp the car around till then. Then I will be dropping the engine out from the bottom to tear it down. Probally take off the k-member and put the k-member back on to roll the car around. Maybe I have a lifter so collapsed that. its just messing everything up.
Ski
Ski
That could be a possibility. I will pull them out after I get the car back from the body shop next week. I will check the gap, and if anything put them down to .45
Thanks.
Ski
Thanks.
Ski
Hi Ski,
When you pull the plugs check the color of each plug, they should be a little brown - if you find one that is darker or a different color that will be the problem wire/plug issue. The LS1 is not the easiest engine to work and some people have cracked the plug(s) installing them or you could have a bad wire. Check the resistant of each wire - the after market wires are about 40 ohm, don't know what the factory wire is. Again if one is out of range that could be the problem. Bad in this case is a high resistant.
Thanks
Bill
Thanks
Bill
That is the only variable that has changed. Right after that my gasmileage went to crap. So, you tell me. Like if you have 4 matching tires and your car drives straight. Then you change to 4 different tires and your car drives all crazy. Must be the tires. Thats why. I consider myself pretty mechanically capable of almost anything. I'm not an idiot. I only posted this incase someone esle had a similar experiance and found out what it was. Maybe then they could provide me with some insight. Thanks everyone for there input. I'll just have to deal with it for a few more weeks. Then I'm dropping the engine out and tearing it down. Thanks.
Ski
Ski
1 Post
I have TR55's. No problems with mileage from that (can't say the same for other parts on the car.....) Anyhow, check the resistence in the wires and that they're connected properly (as mentioned before) Also check and be sure a spark plug didn't loosen up and is backng out of the head. The torque on then is only like 12lbs. Double check the gap too.
I know it's frustrating....but the NGK plugs won't decrease your gas mileage... unless one is damaged. Didn't by chance drop ne during install, did you? That could create a prob if the ceramic has even a hairline crack.......
Good luck and hope this helps......
Location: Live Oak, FL - in the woods where the creatures lurk.
I would not gap the TR55's @ .045. I believe NGK advises a gap change of no more than .010 from the off-the-shelf gap (they usually come gapped @ .059). I've run .055 - to .059 with absolutely no problems or change in gas mileage. I've done 5 plug changes in 130K miles, all NGK TR55's.
