Differnce Between 1-3/4" & 1-5/8" Headers?
Curious on what the signifigant difference between the two diameters is....other than the fact that one's larger than the other. Does the 1-3/4" flow better or something due to more volume inside the tube. Does it matter whether the headers are shorties or LT's?
From what I understand the smaller the primary tube (within reason) the more TQ your motor will have in a given rpm range but may suffer in peak HP. A larger diameter primary tube may give you more peak HP but a little less TQ than a slightly smaller primary tube. Length of tubes play a role in this also...
