best bang
best bang
ok just want to know what would be the best mods for the cash.. the car is basically stock a4 now but wnat to do some easy mods... but want to dig into it too much... and by best i mean most gain on the street (best for rollon races) and most fun thanx
justin
justin
Do some searces on first mods and read all of these, plus any other stickies or links in JRP's sig you come across.
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/361959-so-you-wanna-fast.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
https://ls1tech.com/forums/showthread.php?t=139142
The best bang for the buck is nitrous. It is temporary and needs refills though. $1,000 or a little more should get you off to a good start. If you want to go that route read stickies and search in the nitrous oxide section. Hard to beat $1,500 max for 100-125 rwhp and potentially even more torque.
Best single mod for an A4 is a torque converter. $1,380 out the door got me a TCI converter, transgo shift kit, B&M tranny cooler, +2 quart finned/aluminum transmission pan, autometer trans temp gauge, installation of all parts and basic tune for shift points and other odds and ends. You don't need the transmission pan, but should also get subframe connectors and drag radials at that time if you don't already have them.
The essential first mods are a cat-back or cutout and a lid.
Get some sticky rubber and a nice stall, and run people from a dig. You'll be impressed with how much that alone will wake up the car, and honestly it's not too hard to swap converters. Hell, I did my entire tranny swap on two jackstands in my back parking lot that was on rocks! Not to mention no tranny jack
justin
justin
As any Ls1 is pretty quick stock you need only do a few things.
-Rear end gears, I'd probably go for 3.73 or 3.42 depending on what you already have. This will increase SOTP (seat of the pants) feel yet still be smooth and retain good highway manors.
-Shift kit, it'll make the shifts more positive and make the car much more responsive, which adds to the excitment of driving. Also it'll be tons better if you like to hit the twisties too.
-Cat back, will give a smidgen of HP but what you want it for is the sound. Allow it make the noises a muscle/pony car should
- Lid, well for the money why not it will add a bit more poke and imporve throttle response. (keep the stock paper filter, it'll work fine).
That should make it a whole lot more fun. If you live near some decent driving roads (bends and corners) then a few chassis/suspension mods and brakes may well be worth it. There's no point having MASSIVE BHP if you can't make use of it.
Originally Posted by 300bhp/ton
I would guess if ET's are not a main concern the the GRIN factor is.
-Rear end gears, I'd probably go for 3.73 or 3.42 depending on what you already have. This will increase SOTP (seat of the pants) feel yet still be smooth and retain good highway manors....
Originally Posted by blkZ28spt
Converter > gears
I never driven a high stall motor before however. What are they like once rolling?
Maybe slicing thru some great twisty country roads, using mainly 2nd and 3rd gears, or some tail out loutish behaviour.
Ta.
for drag racing I would guess yes.
Ta.
Ta.
get a lid and a cutout. lid= ~75$ used and free installation, that will give u between 8-12RWHP and then a cutout is 35$ plus maybe 50$ to have it welded into place, that will get u between 8-12RWHP as well. all said, for around 150$ installed, u could gain around 15RWHP at the least. i say 15 because ur car is an A4 and will lose more power thru the tranny than an M6 would. in my M6 WS6 wiht just lid and cutout, i put down 329RWHP and 338RWTQ. not to bad for 150$!!
