Rattling noise from Rear End - Drivng me Crazy
Ok here is my situtation. I have done a search on here and read a couple of threads unto which I am going to try some of the things and see if they resolve the problem. However I wanted to post my specific problem and see if anyone else has had this and has fixed it yet if so.
ISSUE:
Driving down the road and hitting small bumps suck as concrete spacers, and or big bumps suck as raises in road, I hear hear a rattling noise. It sounds as though it is coming from both sides. I have had the problem for a while now and its getting to the point to where I am about to shoot myself. I am tired of driving down the road and having a nice looking car that sounds as though its about to fall apart.
Here's what I have noticed:
I have noticed that my rear calipers have some play in them. Could they be the culprate? I have also read a lot about LCA getting loose and needing to be be retightend (Something I need to Check).
Has or does anyone else have this problem and if so have you guys ever fixed it. If so how
ISSUE:
All of those suspension upgrades with the urethane bushings will definitely make noises. It goes with the territory. My Trans Am did the same thing. The stock rubber bushings absorb most of that noise. Having the urethane bushings transfers all of that noise into the passenger compartment.
Aside from that, my torque arm bolt came loose frequently because of the extra vibrations. Check that, too. Also check the PHB bolts. Thread locker is your friend here.
The thing is I just put the Adjustable Panhard Bar on hoping that would help. But to no avail it still makes noise. I guess I should have stated that besides that is listed everything thing is still stock meaning LCA's, Shocks, springs, everything. The car has 81,100 miles on its so i know its gonna make noises, but this noise is not squeaking, it almost sounds like the caliper is rattling. I dont think its the caliper though. Hard to pin point it seeing as how I cant be under the car when it rattles like that to find out where it is coming from. Maybe I should just take the LCA's completely off and put them back on and make sure they are tight?
Unless the rear end is going out.
no i doubt its my rear end
Like i said its a rattling noise, kinda of like having a whole bunch of silverware in the drawer and sticking your handing in a clanging them all together. Just sounds like something is loose that needs tightening. If I had a lift I could check everything out! Kind of hard to look for loose stuff on your back
Check the LCA bolts! and the bushings. Mine came loose and rattled, until I took them off, locktite on the threads and snugged them up.
I would say the Panhard, but you replaced it, as my neighbor's car was rattling around, on his stock one, turns out the bushing was shot.
Before you take the LCAs out, just pick up another set, always some forsale cheap on here....
Yeah I am thinking it may be the LCA's I have read a lot about the stock ones rattling.
Maybe I'll just take them out and not put anything back in
might get a little wheel hop though
Sounds like either loose bolts or you rear end. Tighten all the bolts, and then look around the pinion area of the rear end to make sure its not leaking, if it is, its mostlikley low on fluid.
rattle noise
i had the exact same problem on my 01 ws6, the noise was coming from the rear passenger side. the noise was way worse once i was driving slow in a parking lot, you couldnt really hear it on the hw. anyway i took it to a buddy of mine and he said it was just a couple of loose bolts near the rear lca on the passenger side. he tightened all of them and i havent heard the car this quiet since i bought it. before you buy anything just tighten the bolts, should fix the prob.
Sweet thanks you guys. I'm gonna try and get it up soon so I can tighten everything up. I mean hell it has 80,000 miles on it. I'm sure something is loose under there.
Damn...i have a similiar noise. Going over the same type of roads i have a rattling noise coming from the rear. Never got under to look what it was as i have no idea what to look for. I'll get under there sometime and check all the bolts.
I figured out what it was from someone else on here. Its the calipers and the brake pad retainers. The calipers have a little bit of play in them and when I hit bumps in the road the calipers rattle. If I tap on the breaks when going over a bump the rattle doesnt happen. They said the fix was to go to GM and get some GM pads they come with new retainers and that should fix the problem.
