gains with mild porting/3-angle valve job
Old 08-25-2005, 10:42 AM
danf1000's Avatar
Default gains with mild porting/3-angle valve job
what kind of gains expected, like to swap cam to a 114 lsa medium lift (~520?) and was wondering if blending in the short side radius (if there is one), reworking valve bosses, and 3-angle valve job mght be worth it. any noteworthy casting ridges to shave away??
but what is the expectations on just the head work???
Old 08-25-2005, 12:14 PM
GuitsBoy's Avatar
Heads came stock with a three angle valve job. Leave the valves unless you want to move to bigger sized valves. As for where to remove material, I cant really say, but you might try these posts:
https://ls1tech.com/forums/showt...me+ported+heads
https://ls1tech.com/forums/generation-iii-internal-engine/316041-pics-my-bo-white-ported-241-s.html
https://ls1tech.com/forums/generation-iii-internal-engine/316237-just-starting-head-porting-project.html
https://ls1tech.com/forums/generation-iii-internal-engine/346464-pics-ported-heads-help-me-port-mine.html
Old 08-25-2005, 07:51 PM
danf1000's Avatar
anyone else???
