need some opnions
need some opnions
well last night I went and did some racing and run without any problems and this morning I started the car up and it was knocking wtf, and it had a cam sens. ses light so i pulled the timing cover off and and the cam gear bolts were backed out and hitting the cover and I just started to put them back in and decided to pull the gear of and see if it hurt the cam and the roll pin is gone I assume in the pan, the question is do you think I need to change cams incase the hole is oblong or try to put a new dowell in and hope for the best. thanks
