What MPH to lock up 4L80E?
For normal driving I have it set to lock up at 45mph.
What is the best speed to lock it up at for street racing?
Would the strip require a different lockup speed?
Just started playing around with my TCI T-Com controller after I got the motor running right - this thing is freakin awesome! So much control over so many different parameters... You can set it to do the whole split personality thing (mellow vs. slammin shifts when you have your foot in it!).
Thanks,
Jim
Thanks,
Jim
I set mine to lock up at 55mph in 4th gear only. It depends on what converter you used on whether you can set it to lock at wot for racing. I bought a 5 disc vig converter to get wot lock up. If you only have a single disc don't lock it under wot. If you do have a multi disc then lock it up right after your 3rd gear shift point.
