Before you dismiss reverse split cams...
remember, some of the most popular LS1 cams are reverse splits (more intake duration than exhaust duration) at some point in their function. Take the FMS F-13. According to the Cam Doctor it looks like this:
___________________________________________ 0.006 0.050 0.200
Intake Duration - ID_______________________ 281 230 150 F-13 INTAKE
Exhaust Duration - ED______________________ 285 232 148 F-13 EXHAUST
Lobe Center Angle - LCA (also known as LSA) 112 112 112
Intake Centerline - ICL____________________ 108 108 108
Intake Valve opens - IVO___________________ 32.5 7 -33 BTDC (- indicates ATDC)
Intake Valve closes - IVC__________________ 68.5 43 3 ABDC
Exhaust Valve Opens - EVO__________________ 78.5 52 10 BBDC
Exhaust Valve Closes - EVC_________________ 26.5 0 -42 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 116 116 116
Overlap____________________________________ 59 7 -75 degrees
Notice how there's more intake duration at .200" lift than exhaust? And since the heads are most effective above .200" lift, I'd have to say reverse split cams shouldn't be dismissed as being ineffective too quickly. Funny how so many on this site get caught up in duration at .050" only and fail to look at the big picture.
FWIW, my Thunder Racing TRak cam is also a reverse split cam at .200" (157/155). Works for me!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LS1Tech Co-Founder
I had the MTI X1 (230/227) in my last SS, and it pulled 10 rwhp higher than any other heads/cam combo at the same dyno day....and I did it with cats on the car and a factory 3" catback. There were quite a few cars that day with huge loping cams and offroads and cutouts, etc...
Bigger isn't always better. Louder isn't faster. Reverse splits work great.
1 Post
Ed
Am I right in assuming that a reverse split cam will not give up much if any low end (idle-3,000 rpm) torque? I like the idea of a custom 234°/228° with say .598"/.589"ish lifts on a 111° IC +3° (108° IC) . Kind of right between the TR 230 and 236 reverse cams with more lift .
nice info. not to be a stickler, but if you use the "code" tags you can get nicer looking charts that are eaiser to follow (keeps spacing of all characters equal):
tried to make it clearer patrick. thanks for your research also!
Code:
A B C D E 1 2 3 4 5 a b c d e
Code:
___________________________________________ 0.006 0.050 0.200 Intake Duration - ID_______________________ 281 230 150 F-13 INTAKE Exhaust Duration - ED______________________ 285 232 148 F-13 EXHAUST Lobe Center Angle - LCA (also known as LSA) 112 112 112 Intake Centerline - ICL____________________ 108 108 108 Intake Valve opens - IVO___________________ 32.5 7 -33 BTDC (- indicates ATDC) Intake Valve closes - IVC__________________ 68.5 43 3 ABDC Exhaust Valve Opens - EVO__________________ 78.5 52 10 BBDC Exhaust Valve Closes - EVC_________________ 26.5 0 -42 ATDC (- indicates BTDC) Exhaust Centerline - ECL___________________ 116 116 116 Overlap____________________________________ 59 7 -75 degrees
Our plastic OEM LS6 and PORTED FAST intakes simply will not flow enough air to make the AFR 205 head perform to its full potential much less the AFR 225's potential. So using reverse split cams with our restricted intake sounds good on paper any way.
Originally Posted by gollum
This affordable $279.50 Patriot cam cam looks very interesting to me.
232/230@.050, 110 lsa .580 lift
Originally Posted by gomer
I did some of the pre-production testing on that cam. I'll look for the dyno graphs from it. I do remember it being a choppy idling sob.. lol.
Originally Posted by Beast96Z
It all depends on the set-up. One must also look at the complete profile of his set-up before determing a givin lobe.
__________________
Originally Posted by JS
Do any of u cam professors race your cars
I've been 10's ON MOTOR with an off the shelf TR 224 no big cam profiles,secret under the curve horse manure,lobe design bs....Just an off the shelf TR cam
A 3150 pound car with an A4 and a 4400 stall?
