hows this setup for my future 98 z28.
After this year of college im deffinately going to buy a 98 z28 with a 6 spd and ive had alot of time to put together my set up for under the hood. The list below is everything i plan to do to the car after is paied off. This will all be done at the same time so i dont have to pull the engine out of the bottom of the car more than once. So please comment on my setup and pointers on what would make it better. this car will be street driven in the summer. Also if you could give estimates on hp/tq numbers too that would be cool.
-SLP zl402 short block low compression 9:1 compression
-AFR 225cc heads with rev kit and roller rockers
-procharger d-1sc kit with new bigger intercoolers
-comp cams XR269HR-14LS1 Hydraulic roller camshaft .525/.532 lift with 114 degree seperation 1300-6300 rev kit
-quicktime performance headers and timing chain cover with larger oil pump
s-lp heavy duty timing chain
-fast 90/90 set up with ls1speed fuel package set up thinking about buying fast fuel rails intead of the ls1speed ones.
-Be cool radiator to cope with the procharger overheating problem ive heard about.
-going to upgrade to 55 lbs injectors from the 45 lbs ones that come with the procharger kit
-Borla cat back exhaust
-MOser 12 bolt with posi and 33 spline axles and carbon fiber drive shaft
-msd blaster coils with msd wires and NGK TR6 plugs fir a cooler spark
- i plan on installing a full BMR chassis setup later on.
Thanx
Thanx
