V-9 Rated for 575hp? Is this too small?
Looking at a great deal on a used V-9 Kit. I see on vortech's website its rated for 575hp, is this rwhp? Because I've seen people making this much or more with this head unit right? What kinda power could I expect with my combo and my cam FM14 112.
Really looking for 600rwhp with a good tune (11.5:1 AF, 21-24 timing). This is my daily driver
Thanks
Travis
Thanks
Travis
Inspector 12 has made that kind of power. Another member has made a little over 600.
With heads and cam it should be able to do it.
I don't recommend running that cam with the sc setup. 21-24 degrees of timing is too much too run on a fi setup unless your running methanol.
your dynamic compression is considerably raised when you go boost.
you have much to learn young grasshopper.
read up in here, use the search and you too will become a master in the dark side.
