welder/welding questions (i just got a little welder)
well guys i had always wanted to weld and my uncle is letting me borrow his welder and it is a little 70 amp 110 volt welder. flux core, adjustable feed, and high/low output.
I have precticed welding alittle exhaust tubing in the past days just playing games and i have a couple of questions about what is happening.
First off sometimes i weld and all that it does is ballup, when there are two pieces of pipe together it would make a nice clean bead, however if i am just making a bead somehwere else on the pipe i am doing pretty decent.
also sometimes it will burn a hole right through the pipe but not weldit.
These are a couple of the things that i am having problems with and looking for a little help with them
Thanks
Louie
Thanks
Louie
if it burns through its too hot. what kind of flux is it? i dont remeber off the top of my head, but i dont think all flux cores weld mild steel (at least for best strength, looks etc..). practice make perfect though. play around with the adjustments a lot and make sure to clean the surface with a wire brush or grinder. have fun
oh ya, and when it ***** up, stop welding, cut off the tip of the flux and continue.
ok cool thanks, also is there a set standard as far as what 70 amp 110 volt will be able to weld. once i get the hang of it i will get a little more powerful welder bu i figure this is good to learn on and i am just looking for what metal is the best to use to get the hang of things.
Thanks
Louie
Thanks
Louie
just get some scrap mild steel to lay some beads down onto.......when you're joining the two pieces, i'm guessing you left a gap, which lets the metal fill in, as opposed to when you're welding ontop of a solid piece it may "ball up" because the filler metal has no place to go(especially if you have the welder set to weld thin exhaust pipe and you are trying to weld something else thicker) if you are burning through you need to turn down the heat/move faster, if you are balling up you need to turn up the heat and/or slow down the wire feed......
hobart, miller, and lincoln all have pretty good websites with faqs and message boards too
-josh
-josh
