What rear end gear do I have?
Well, if it a real WS6 they should be 3:23's. I think the code on the door is GU5, but it's been a while since i've looked. I'm not shure what kind of RPM's I spin at 50mph, but at 70mph it's right at 2grand with 3:23's.
Originally Posted by Mr. Trick
I read on here somewhere that if you had an aluminum driveline that you 3:23's, and if it was steel you had 2:73's. Is there any truth to this?
Yes that is true. My car came with 2.73 gears and a steel driveshaft. I had to buy an aluminum driveshaft and went with a series 3 carrier and 3.42 gears. For the $300 they charge from the factory for the "performance axle" it's worth it for the 3.23 gears and aluminum driveshaft.
