again, TCS off and LOW TRAC light come on when reving?
Old 09-18-2005, 02:56 PM
WS6FirebirdTA00's Avatar
Default again, TCS off and LOW TRAC light come on when reving?
well i ran the car got it warm and we had a dB test out at autofair for loudest exhaust. shut it off and then restarted when they came back. let it run for a second, oil and coolant temps were up i wanted to get it hot so i didnt have to worry about springs going goodbye lol. well then i went to rev and hit it quick and saw the lights come on. this happened in the past at like 3000 rpms and this time i wanna say it was between 3-5 im not 100 % sure. then i went to hold the revs to get a good reading and at about 5000 rpm or so the tcs off light came on. abuse mode it turned to 6800 so i dont get it. although there is a start up fuel shut off at 5000 dont know if that has anything to do wtih it. any ideas? i only notice this after starting the car and doing it after start up
Old 09-18-2005, 09:12 PM
any ideas?
Old 09-18-2005, 10:20 PM
HumpinSS's Avatar
The table i wanted to point you to isnt available in HPT unless i missed it, sorry but i dont have an answer for you. Anyways the tables you are looking for are the TPS vs RPM test. Are you also throwing P0121.
You could also try setting Egine Diagnostics---> P0121 Map tests to some higher value so the test isnt run at all
Old 09-19-2005, 11:24 AM
ok thanks, ill try and check that out, the check engine light did nt come on on me when it happened
